Marcus Pereira
PC Specification: 4 GB RAM, GTX 660, Core i3 3240
Bought 3 licenses.
Thu Mar 20, 2014 3:36 am
bought 3 licenses using the license dropdrown option 3 on yours site.
1. Mine.
2. My Friend.
3. My friend.
The three have been recorded normally. If my computer is a problem I can usually reinstall? Run the risk of being banned?
How can I be banned?
How the program identifies the machine used was formatted?
Re: Bought 3 licenses.
Tue Mar 25, 2014 3:53 pm
Your license can be canceled if you are using your three licenses outside of one household or company.
Marcus Pereira
Tue Mar 25, 2014 6:21 pm
Unfair! On the website says 3 non-commercial licenses. I'm not selling and yes, I bought 3 licenses for my friends and me.
Thanks
Wed Mar 26, 2014 10:09 am
2.2.2 Multi License
You may install, activate and use the Software on a number of computers up to the purchased
number of licenses at the same time using the same serial number. You may not run the
Software on more computers than the purchased number of licenses at the same time using the
same serial number. Multi license is intended for a single company (with commercial license),
single user or members of the same household.
http://download.mirillis.com/files/Action_EULA.pdf
Marcus Pereira
Wed Mar 26, 2014 5:29 pm
The license is only running on 3 computers. Well I bought 3 licenses using dropdrown option.
Everything okay?
Fri Mar 28, 2014 4:19 pm
You can get detailed information about multi-license from our sales team (sales@mirillis.com).
