Action! 1.19.0
Thu Mar 20, 2014 10:04 am
Action! 1.19.0 is now available with 2 new features!
Changelog:
- NEW FEATURE: 120 fps video recording in AVI file format
- NEW FEATURE: Support for DirectX 8 games and applications recording
- Stability improvements
- User interface improvements
Please note that Action! player does not support playback of 120fps recordings and you need to use 3rd party software to play or edit 120fps recordings.
WebMaximus
PC Specification: Intel Core i7 2700K, GTX 680, Win7 x64
Re: Action! 1.19.0
Thu Mar 20, 2014 3:08 pm
Cool to see how you keep updating your already great software, I'm still amazed how low the FPS footprint is while recording if even noticeable!
One simple thing I've been missing though already since I bought Action! is the ability to mark several video clips for export rather than having to export them one by one.
Is there any chance you could add that functionality?
LtMatt
PC Specification: 2700k, 2x290 Crossfire, Win 8.1 64 bit.
Re: Action! 1.19.0
Thu Mar 20, 2014 3:22 pm
WebMaximus wrote:Cool to see how you keep updating your already great software, I'm still amazed how low the FPS footprint is while recording if even noticeable!
Any tips for reducing the performance hit of recording? I game at 1440P and currently use the MP4 AMD APP option to record. I notice sometimes the gpu usage drops quite low whilst recording.
Specs
2700k@4.8gh\z
2x290 in crossfire
16gb DDR3 2133mhz
250GB SSD
1440P monitor
WebMaximus
Re: Action! 1.19.0
Thu Mar 20, 2014 3:29 pm
I record using AVI format @ 30 FPS and video size set to original which is 1920 in my case when recording my desktop and I use the High quality recording setting under the Settings tab.
Using these settings I don't see any FPS drop at all but I guess it also comes down to what CPU and GPU you have. I'm on a 4770K @ 4.5 GHz and a GTX Titan so I have a fairly powerful computer.
LtMatt
Re: Action! 1.19.0
Thu Mar 20, 2014 3:33 pm
WebMaximus wrote:I record using AVI format @ 30 FPS and video size set to original which is 1920 in my case when recording my desktop and I use the High quality recording setting under the Settings tab.
Maybe i should try AVI then? Maybe its because im at 1440P res but there is a performance hit and it comes with gpu usage dropping, as im on crossfire. As you can see from my spcs above, i have a super fast pc.
WebMaximus
Re: Action! 1.19.0
Thu Mar 20, 2014 3:37 pm
My guess is as good as your's, maybe someone else with more knowledge could comment what settings are best to use to keep the FPS footprint as low as possible.
All I know is that using the settings I mentioned in my post above I don't even notice when I'm recording :)
Daniel Dietrich
PC Specification: Windows 8.1_1, Radeon HD 6770, E6500
Action! 1.19.0
Thu Mar 20, 2014 6:59 pm
Thanks for update! Can you add in next version possibility to deselect all hotkeys? (four of them are locked) :)
Claunator
Re: Action! 1.19.0
Thu Mar 20, 2014 8:01 pm
WebMaximus wrote:My guess is as good as your's, maybe someone else with more knowledge could comment what settings are best to use to keep the FPS footprint as low as possible.
My experience has always been the same: Recording with AVI Original 30fps with High quality gets me barely any lag during in-game. And by barely i mean very tiny lagspikes here and there, mostly 0.1-0.4 seconds. Other than that though, it feels like i'm not recording at all :)
My other preference is mostly the same, but with 720p at 60fps. During recording the fps jumps almost constantly between 40-60fps, depending on the game. But it hardly matters because every playback i've watched runs perfectly.
WebMaximus
Re: Action! 1.19.0
Thu Mar 20, 2014 10:49 pm
I would still appreciate an answer to my question regarding selecting multiple video clips for export.
Laurent13
Re: Action! 1.19.0
Fri Mar 21, 2014 5:56 am
For the next update i hope you remove the unbalanced volume audio recording (repartition).
For exemple, i recording my microphone to 80% but, my minecraft and skype is recorded to 20% it is not logic :shock:
Hopefully :ugeek:
