LtMatt
PC Specification: 2700k, 2x290 Crossfire, Win 8.1 64 bit.
Reducing The Performance Hit
Thu Mar 20, 2014 3:22 pm
Any tips for reducing the performance hit of recording? I game at 1440P and currently use the MP4 AMD APP option to record. I notice sometimes the gpu usage drops quite low whilst recording.
Specs
2700k@4.8gh\z
2x290 in crossfire
16gb DDR3 2133mhz
250GB SSD
Re: Reducing The Performance Hit
Tue Mar 25, 2014 3:51 pm
MP4 or AVI?
Montago
Wed Mar 26, 2014 9:40 am
LtMatt wrote:Any tips for reducing the performance hit of recording? I game at 1440P and currently use the MP4 AMD APP option to record. I notice sometimes the gpu usage drops quite low whilst recording.
Specs
2700k@4.8gh\z
2x290 in crossfire
16gb DDR3 2133mhz
250GB SSD
With 2x R290 you shouldn't be able to notice that Action is recording..
- Are your recording Harddrive fast enough (assuming its not your SSD)
- Have you tried disabling Crossfire ?
AMD has notorious problems with frame pacing and in some cases with CrossFire - Try lowering your GFX quality so that you ALWAYS have more than 60 or 70 FPS..
Also, enable VSYNC.. it's much better when recording to have it enabled !
LtMatt
Sat Mar 29, 2014 10:29 am
radi wrote:MP4 or AVI?
MP4 or AVI.
Can you give me some recommended settings to try for best performance?
LtMatt
Sat Mar 29, 2014 10:30 am
Specs
2700k@4.8gh\z
2x290 in crossfire
16gb DDR3 2133mhz
250GB SSD
I have a 250GB Samsung 840 Basic SSD so not sure that is the problem.
I use vsync already. The problem is the fps dropping low. Nothing wrong with AMD frame pacing, works wonderfully so its not that. Microstutter is a thing of the past for AMD these days.
