crl2007
Action! and VMWare bug (INVESTIGATING)
Fri Dec 02, 2011 8:28 pm
If a VMWare virtual network adapter is present, then Action! takes a very long time to start. I disabled the virtual adapter and left only my connection and Action! started as it should. Please fix this bug.
P.J
Re: Action! and VMWare bug
Sat Dec 03, 2011 7:52 pm
There're 4 or 5 vmware services too that I usually disable them to make PC runs faster.
Sun Dec 18, 2011 8:55 pm
Thank you for reporting this problems.
We are investigating it.
Can you please make a region screenshot of task manager with list of VMWARE processes visible?
