andrew123
PC Specification: Intel Core i5, Nvidia GT330M, Windows 7
I have a problem!
Sat Mar 22, 2014 2:40 pm
When I play a mkv video file (720p/1080p), the basic video controls don't have effect... for example": i switch saturation/contrast to 25 and nothing happens to the image.
What should I do? :D
Re: I have a problem!
Tue Mar 25, 2014 3:45 pm
Could you post a screenshot of your Playback Options?
andrew123
Fri Apr 04, 2014 11:12 am
In the image below you can see that i have set the luminosity,contrast and saturation to -100 without any effect...
Fără titlu.jpg (67.09 KiB) Viewed 18229 times
Mon Apr 07, 2014 5:13 pm
It's really weird. Does it occurs only with MKV videos?
andrew123
Tue Apr 08, 2014 1:33 pm
No, it happens to any kind of video file... I was thinking that somehow my video card doesn't allow the player to use its settings but i opened nvidia control panel and in video and image settings there was checked "Use video player settings".
I hope there is a solution! :D
Tue Apr 08, 2014 4:07 pm
I'd suggest to check your graphic drivers first. If they are up to date try forcing your Splash player to run under Nvidia graphic processor if it's running on Intel's one. You can change it in Nvidia control panel (manage 3d settings).
