Funseca
PC Specification: Windows 7
Webcam doesn't appear in the recorded video!
Tue Mar 25, 2014 6:35 pm
Ok, so I've bought a Logitech C270 and when I previewed the camera was showing but when I recorded the webcam wasn't there!(and no, there was nothing else using the webam.)
So I went to buy a new webcam a Microsoft lifecam hd 3000, and the same thing appenned... I don't know wants wrong but I want it fixed and fast! I payed for the product and it just doesn't work!
Re: Webcam doesn't appear in the recorded video!
Wed Mar 26, 2014 10:00 am
Webcam may not be working in two cases:
- Check if you have Perfect Video Match mode enabled. If yes, please disable it.
- Check if you have selected Record Mouse Cursor, it's required to show the webcam properly.
Funseca
Wed Mar 26, 2014 4:39 pm
Thank you finally!
Funseca
Wed Mar 26, 2014 4:46 pm
But can you tell me why it records the webcam in 4:3?(no the option is not enabled)
Fri Mar 28, 2014 4:18 pm
Funseca wrote:But can you tell me why it records the webcam in 4:3?(no the option is not enabled)
Maybe your webcam is set to this setting.
