Freddan962
PC Specification: i7 4770k, Asus GTX 680, Windows 7 Ult 64
How do I not record the Teamspeak 3 sound while recording?
Wed Mar 26, 2014 11:07 am
How do I not record the Teamspeak 3 sound while recording gameplay?
Re: How do I not record the Teamspeak 3 sound while recordin
Fri Mar 28, 2014 4:18 pm
TeamSpeak sound comes through your sound card and it's considered as system sounds. There is no possibility to not record it.
Dani445
PC Specification: I7 860; HD6970
Sat Mar 29, 2014 2:23 am
if you have 2 sound outputs, like a sounds card and an HDMI output you can use a spliter for your game sounds to be outputed to you hdmi exit as well as your sound card and set action to record the system sounds from the hdmi exit, that way it only records the game sound
Abuser
Sat Mar 29, 2014 7:36 pm
Easy use virtual audio cable. Ill make a tutorial later.
