SoupOrHero
PC Specification: Windows 8.1 64-bit
Active Desktop Region Does Not Appear
Fri Mar 28, 2014 9:36 pm
So I am unable to use the Active Desktop Region of Mirillis Action. Everytime I click on it the Mirillis panel disappears from my screen, and there are no screen region bars. I have to task manager delete Mirillis everytime I try this. Does anyone know why? I have reinstalled the program many times. Not sure whats going on.
Action Version - 1.18.0.0
Operating System
Windows 8.1 64-bit
CPU
Intel Core i3/i5/i7 4xxx @ 2.40GHz 54 °C
Haswell 22nm Technology
RAM
8.00GB Single-Channel DDR3 @ 798MHz (11-11-11-28)
Motherboard
Notebook W350STQ/W370ST (SOCKET 0) 58 °C
Graphics
Generic PnP Monitor (1920x1080@59Hz)
Intel HD Graphics 4600 (CLEVO/KAPOK Computer)
2047MB NVIDIA GeForce GTX 765M (CLEVO/KAPOK Computer) 42 °C
Storage
698GB Seagate ST9750420AS (SATA) 49 °C
Optical Drives
Slimtype DVD A DS8A9SH
Audio
VIA High Definition Audio
SoupOrHero
Re: Active Desktop Region Does Not Appear
Thu Apr 03, 2014 6:17 pm
Any help would be appreciated! :D
jax<>
PC Specification: Intel 3770K, Gigabyte 660GTX, Windows 7
Thu Apr 03, 2014 9:51 pm
Latest Version is 1.19.1 you might try update?
jax<>
Fri Apr 04, 2014 7:56 am
Probably your region is out of your screen. Press "0" to reset your region settings.
SoupOrHero
Fri Apr 04, 2014 9:06 pm
The "0" fixed it. Thank you!
