TirexiHD
PC Specification: i7 5930k, 32GB DDR4, GTX1080, Win 10.
TESO is not game?
Sun Mar 30, 2014 11:49 am
Hi.
I play Elder Scrolls Online and the Action! is not see the game running. Why?
I use Fraps. Way way better. :)
THX.
<<<Rampage V Extreme - i7 5930k @ 4.5Ghz - 32GB DDR4 3000Mhz - MSI GTX 1080>>>
Claunator
Re: TESO is not game?
Mon Mar 31, 2014 6:56 pm
Run the game as admin. That has helped me many times.
Kingspian
PC Specification: Windows 8.1, I7, Nvidia 550ti
Tue Apr 01, 2014 9:35 am
You're not the only one that runs TESO ;). I play TESO too! I've been recording Action for 7 hours and gave me tons of problems and crashes. It keeps stopping the recorder every hour in a half. Should run up to 7 hours right? I sent Action a email, got a reply and sent my pc info. I hope this issue will be fixed otherwise I might be stuck using fraps :/. And believe me Fraps gives lags. Action did not. Just crashing and out of sync with my webcam so webcam is out. It just couldn't keep up with everything. I'm using Windows 8.1. I hope I hope this can be fixed.
