resetes
PC Specification: i7 3770k, HD 7970, 8Gb RAM, Windows 8
Grey screen will go away if I buy the product?
Thu Apr 03, 2014 12:36 pm
Please read to the bottom.
Hi! I tested a LOT of programs to record games. Last I tried, Action!. I liked it, but it has a problem. I use a cracked version for TESTING and this are my problems:
- Grey screen when recording anything. Sound it's working.
- MP4 doesn't record sound.
Will these problems go if I buy the complete version? I really like this program, but with this problems I don't know If it's worth buying it.
If not, what should I do?
Thanks!
Re: Grey screen will go away if I buy the product?
Fri Apr 04, 2014 7:59 am
Good luck with this crack crap. No wonder that your Action! is bugged. Free trial is for testing purposes, not cracked one.
