MatG-DK
PC Specification: i7 4700HQ, GTX780M, Windows 8 x64bit
NFS Most Wanted 2012 not working?
Thu Apr 03, 2014 1:58 pm
Hi there, i just downloaded the latest trial and just recorded some gameplay some of my favorite games BF4 etc.
In almost every game it works without any problems and im about to pay this topclass software :)
But, then i started "Need For Speed Most Wanted 2012" and Action! do not recognize it :cry:
Been trying to found out about if others have the same problem or if it was my rig that has something missing, but i have absolutely no clue about why it wont work?
Have found others that have used Action! to record "NFS MW 2012" gameplay, on YouTube, so im guessing that it should be able to work and the game is supported, but again im not sure anymore.
Can anyone plz help??
Regards
Re: NFS Most Wanted 2012 not working?
Fri Apr 04, 2014 7:58 am
Have you tried running NFS first and then switch to desktop to run Action?
MatG-DK
Fri Apr 04, 2014 7:59 am
No, but will try that right away ;)
MatG-DK
Fri Apr 04, 2014 8:22 am
No that didnt work..
Was trying to "ALT+TAB" and then start Action! "ALT+TAB " back to game and nothing happend.
Did also try to change recording mode to "Active Screen" instead of "Games and Apps (DirectX/OpenGL)"
that worked when the game was running in Window mode, but stopped recording when i hit "ALT+ENTER" :cry:
NFS MW 2012 does not normally run in Window mode, at least its not supported under Graphic Options in game..
