mage1
PC Specification: Windows 8.1 x64
Some problems with Action!
Thu Apr 10, 2014 8:21 am
I get a random split second black screen when rendering the raw file ".AVI" on sony vegas.
It happens randomly, and it's a hassle to watch your videos carefully just to look for random black screen that occurs.
I haven't tried the MP4 format because it only captures up to 720p. I am recording at 1080p / Original.
The MP4 (AMD APP) captures at a very low bitrate which results in a pixelated raw video.
I also tried the export feature, but the output video lost half of its sound after exporting. And the max video bitrate is only 24.000 Mbps.
That give me no choice but to only use the AVI file format. :(
Elochai
PC Specification: Intel Q6700, BFG 260 GTX OC, Windows 7
Re: Some problems with Action!
Thu Apr 10, 2014 4:20 pm
So you lost the sound when exporting from Action or Sony Vegas ?
How long is the footage ?, I'm use to doing short videos, longest being 15 mins most times so I wonder if this is an issue with long videos.
As for the black screen, does it also show up in Action, or is it only in Sony Vegas ?
mage1
Thu Apr 10, 2014 5:05 pm
Elochai wrote:So you lost the sound when exporting from Action or Sony Vegas ?
From Action!, then saving to my computer. Half of the video duration lost its sound.
As much as possible.. I don't want to export the raw file, because the max bitrate is only 24 Mbps.
Elochai wrote:How long is the footage ?, I'm use to doing short videos, longest being 15 mins most times so I wonder if this is an issue with long videos.
3 - 15 minutes
Elochai wrote:As for the black screen, does it also show up in Action, or is it only in Sony Vegas ?
It only shows in sony vegas.
Elochai
Sat Apr 12, 2014 12:32 pm
Not really sure why your losing your sound, maybe a codec is corrupted in Action.
Could do a repair/re-install to test that.
As for the black screen, if it showing up in Vegas only then it sounds like an issue with how Sony Vegas is rendering the video. They may be able to give you some insight on that. But in the mean time, why not test another video editor like a free one to see if the black screen results also occur ?.
But I hope a reinstall will fix your sound issue.
mage1
Sun Apr 13, 2014 8:33 pm
Elochai wrote:Could do a repair/re-install to test that.
The video lost half of its sound when importing to sony vegas. I tried playing it on windows and it is fine.
Elochai
Sun Apr 13, 2014 8:38 pm
So it sounds like Sony Vegas is messing up with the importing of the Action videos.
I'm not sure if anyone else has had any of these issues with Sony Vegas, I myself use MAGIX Movie Edit Pro 2013 Plus and never had any issues editing my files from Action.
mage1
Sat Apr 19, 2014 6:33 am
mage1 wrote:I get a random split second black screen when rendering the raw file ".AVI" on sony vegas.
After re-installing Action!. This problem does not occur so far.
PixelTwitch
PC Specification: i7 3930k @5.1Ghz, 2x680gtx, Win8.1
Mon Apr 21, 2014 12:33 am
The black screen is a common sony vegas problem I am afraid.
