GaebryelQuintyne
PC Specification: Windows 7 64 bit
Action crashes when done recording and can't open file
Sun Apr 13, 2014 11:01 pm
Hi there.
I used a different setting this time around to record my videos. I used to use MP4 with Intel QuickSync but every 4th video would make Action crash and then I would have to go to Task manager to close the program. I then open it back again and I see the file is there but I can't open it with the Action video player. It says "Failed to open input file". It also says that the file is at varied sizes... Sometimes its 0 bytes or its 300 MB while it should be a bit more than 1 Gig.
Anyway, I tried the MP4 (AMD APP) settings and it was working flawlessly until just now. I just lost a 10 minute video and got the same error (Failed to open input file). Also, this time around, my game also crashed and got disconnected at the same time. The file is 1.5 gigs though. So I know it recorded it but I can't seem to open it... So I believe it is lost to me. This video was like the 27th video I recorded, which I cannot open or do anything with. I am going to continue recording again and hopefully the crash doesn't occur again. Majority of my videos are around 10 minutes each, while 2 or 3 of these videos are maybe more than 10 minutes, like 20 minutes or 15 minutes.
I did get a suggestion to rein-stall and I just did that... Now, hopefully, I don't get this error again, because I cannot re-record my gameplay footage since then I would have to restart all over again and I have already done that once.
If there is any way to open the file, please let me know.
SHEagle
PC Specification: I7 870, 12 GB Ram, GTX 770, Win 7 x64
Re: Action crashes when done recording and can't open file
Tue Apr 15, 2014 9:27 pm
It also happened to me sometimes:
And other times I can see the HUD in red, like if recording all time, but wen I finished open the file and I find that:
http://youtu.be/p23CyWadqoc
http://youtu.be/5z7UX-cjeug
I was recording like one hour on each video, I don't know what happened, but It is really annoying.
Like 30 videos failed on last week, and I tried with options "Active Screen" and "Games and Applications", both fail.
Action version: 1.19.1.
GamerGuy
Wed Apr 16, 2014 4:40 pm
I started having a similar problem after I recently upgraded my Intel gfx driver. Downgraded the driver back to the previous version and now Action works ok again.
Wed Apr 23, 2014 3:38 pm
GamerGuy wrote:I started having a similar problem after I recently upgraded my Intel gfx driver. Downgraded the driver back to the previous version and now Action works ok again.
To which version did you upgraded your drivers when Action stopped to work?
