littlecheese
PC Specification: i5 4670k, R9 280x, Windows 8.1
Problem with FPS counter in HUD.
Fri Apr 25, 2014 2:57 am
It doesnt matter if im recording or not, but the HUD that shows my fps never goes above 60. I know i dont need to know if im getting better than 60fps but i would like it. Is there some sort of setting that I can change to make it go higher?
Re: Problem with FPS counter in HUD.
Mon Apr 28, 2014 6:47 pm
Action! HUD will only show your current fps in benchmarking mode (while it's blue). Once you start recording it will become red and will show current recorded fps instead of current game fps.
littlecheese
Tue Apr 29, 2014 12:01 am
Thats not what I mean. Even when im not recording, but still playing a game where im getting over 60fps (i know this because i can run fraps at the same time and i get lets say 80), it still shows 60... maybe 61. Should i just re download it or something? Im running windows 8.1 if that makes a difference.
