Jaso444
PC Specification: Core i5 4670k, XFX R9 280x, Windows7 Pro
Actions live stops streaming after 1-2 mins
Fri Apr 25, 2014 9:01 am
Hey, I want to do live stream but I cant because my Action! always stops streaming after like 1-2 mins. It still shows live on the HUD but on the site, it always shows offline. I've tried different sites, twitch, Ustream but it doesnt change anything. Is there something I'm doing wrong?
littlecheese
PC Specification: i5 4670k, R9 280x, Windows 8.1
Re: Actions live stops streaming after 1-2 mins
Fri Apr 25, 2014 5:19 pm
Could be your upload speed of your internet? Personally I know i am unable to stream anything higher than 480p because my upload speed is terrible. If i try to go higher it gets choppy or stops. Since you are going to different sites, it sounds like thats the problem to me.
Jaso444
Fri Apr 25, 2014 11:42 pm
Well, it can't be m upload speed because Open Broadcast software works perfectly fine at 1080p...
