leTriko
PC Specification: intel-i5 2380p, hd7850 2gb
AVI or MP4
Fri Apr 25, 2014 4:07 pm
Hello, can You please tell what are the pros and cons of MP4 recording and AVI recording? Which need less requirements?
littlecheese
PC Specification: i5 4670k, R9 280x, Windows 8.1
Re: AVI or MP4
Fri Apr 25, 2014 5:13 pm
AVI is pretty much raw footage and will take a lot of space, which also means you need a hard drive of decent speed. MP4 is more compressed but will take more out of your cpu, unless you are using cuda or amd app with Nvidia or AMD graphics cards. If you want to use MP4 with your CPU then choose the quicksync option. That will give you much better performance. If there is no quicksync option, your CPU may not be capable of it, or it is not enabled. Quicksync is only available in newer Intel processors. What are your specs?
leTriko
Re: AVI or MP4
Fri Apr 25, 2014 5:40 pm
Intel i-5 2380p 3.1Ghz
GV-R7850OC-2GH (GPU)
4gb RAM
Cauptain
Contact: ICQ
Re: AVI or MP4
Sun Apr 27, 2014 11:31 am
Like this:
AVI = Minor consume resources, high FPS, better quality image, better to edit , much more space used
MP4 = High consume resources, FPS OK, image quality good, good to edit and low space used
Claudio
