mike22
PC Specification: win 7 amd fx 8350 gtx 670 ftw 16 GB ram
Idea for the action! player
Sun Apr 27, 2014 3:42 am
I'v currently useing the record microphone into seperate audio track option and when you play the file in action! i cant hear my own voice but all other sounds , yet when its opening in windows media player i can then hear my voice.will this be in the next update etc?
Re: Idea for the action! player
Mon Apr 28, 2014 6:40 pm
You can switch between active audio track in Action! player using "A" hotkey.
mike22
Mon Apr 28, 2014 7:19 pm
radi wrote:You can switch between active audio track in Action! player using "A" hotkey.
can i play 2 tracks at the same time? also is there a way that when you play say for example dark souls 2, all the videos go into a dark souls folder? they had this feature on bandicam but i bought action as its so much better and i hope you implent this feature or allready have it :D
Tue Apr 29, 2014 8:47 am
Unfortunately there is no possibility to play both audio tracks at the same time. However you can play it in Windows Media Player. As for recording. Action! record only your videos into selected output folder.
