Penx
PC Specification: windows 7 64 bit
Live stream crashes Action!
Mon Apr 28, 2014 11:39 pm
I have been trying to Live stream to Twitch for a couple days now, but I can only stream for about 2 - 10 minutes before Action! crashes.
I thought it might be my internet speed but I am at...
Ping - 14 ms
Down - 56 mbps
up - 11mbps
That should be enough to stream at 480p.
I'll have Action! open says Live, watching my stream on the other monitor, then the stream goes offline while the HUD stills says Live, and when I tab out of the game, Action! has crahsed, and to start the stream again, I need to get a new stream key, reload the game, reload Action!, then start the process over again.
Any idea on why it is doing this?
Lazhward
PC Specification: Windows 7 64bit, i7 2600k, GTX580
Re: Live stream crashes Action!
Tue Apr 29, 2014 11:04 pm
I have the same exact problem; Action! works fine at first -- game, audio and webcam -- but crashes after 5 minutes or so.
Fri May 02, 2014 1:02 pm
Could you post a DxDiag report of your PC?
Penx
Sat May 03, 2014 6:17 pm
Here you are sir.
System Information
Time of this report: 5/3/2014, 14:11:35
Machine name: JESSE-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 07/19/12 15:48:45 Ver: 14.06
Processor: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 16384MB RAM
Available OS Memory: 16332MB RAM
Page File: 2809MB used, 29850MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 670
Manufacturer: NVIDIA
Chip type: GeForce GTX 670
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1189&SUBSYS_26733842&REV_A1
Display Memory: 4095 MB
Dedicated Memory: 3072 MB
Shared Memory: 1023 MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor Name: Dell ST2010
Monitor Model: DELL ST2010
Monitor Id: DELF019
Native Mode: 1600 x 900(p) (59.978Hz)
Output Type: HDMI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.3221 (English)
Driver Version: 9.18.13.3221
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 12/19/2013 16:33:31, 18222008 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-52C9-11CF-6757-7E061CC2C435}
Vendor ID: 0x10DE
Device ID: 0x1189
SubSys ID: 0x26733842
Revision ID: 0x00A1
Driver Strong Name: oem79.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section093:9.18.13.3221:pci\ven_10de&dev_1189
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Device Key: Enum\PCI\VEN_10DE&DEV_1189&SUBSYS_26703842&REV_A1
Display Memory: 4038 MB
Dedicated Memory: 1990 MB
Shared Memory: 2048 MB
Monitor Id: DELF019
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-52C9-11CF-6757-7D061CC2C435}
Vendor ID: 0x10DE
Device ID: 0x1189
SubSys ID: 0x26703842
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_104384FB&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6657 (English)
WHQL Logo'd: Yes
Date and Size: 6/12/2012 06:10:44, 4060560 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Headset Earphone (Headset (Afterglow Gamepad for Xbox 360))
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: USB\VID_1BAD&PID_F900&IA_01
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 6.01.7601.18208 (English)
WHQL Logo'd: Yes
Date and Size: 7/12/2013 06:40:58, 109824 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Desktop Microphone (3- Studio - Microsoft LifeCam.)
Default Sound Capture: Yes
Default Voice Capture: No
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Headset Microphone (Headset (Afterglow Gamepad for Xbox 360))
Default Sound Capture: No
Default Voice Capture: Yes
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Programmable Hotkeys
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x06A3, 0x5081
FF Driver: n/a
Device Name: Microsoft® LifeCam Studio(TM)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0772
FF Driver: n/a
Device Name: Steelseries Consumer
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1038, 0x1020
FF Driver: n/a
Device Name: Razer Ouroboros Gaming Dock
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1532, 0x0033
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Controller (Afterglow Gamepad for Xbox 360)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1BAD, 0xF900
FF Driver: n/a
Device Name: ROCCAT Isku FX
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1E7D, 0x3264
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1E26
| Matching Device ID: usb\root_hub20
| Service: usbhub
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Vendor/Product ID: 0x1038, 0x1000
| Service: kbdhid
+ Razer Ouroboros Gaming Dock
| Matching Device ID: hid\vid_1532&pid_0033&mi_01&col01
| Upper Filters: rzudd
| Service: kbdhid
| Service: kbdhid
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Service: mouhid
| Matching Device ID: hid\vid_1532&pid_0033&mi_00
| Service: mouhid
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 36.5 GB
Total Space: 122.0 GB
File System: NTFS
Model: SAMSUNG SSD 830 Series
Drive: E:
Free Space: 945.0 GB
Total Space: 1907.7 GB
File System: NTFS
Model: WDC WD20EADS-00R6B0
Drive: F:
Free Space: 186.9 GB
Total Space: 228.9 GB
File System: NTFS
Model: INTEL SSDSC2BW240A4
Drive: X:
Free Space: 1049.5 GB
File System: NTFS
Model: WDC WD20EZRX-00D8PB0
Drive: D:
Model: HL-DT-ST DVD+-RW GH50N ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
System Devices
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_1E20&SUBSYS_84FB1043&REV_04\3&11583659&0&D8
Driver: n/a
Name: Xeon E3-1200/2nd Generation Intel(R) Core(TM) Processor Family PCI Express Root Port - 0101
Device ID: PCI\VEN_8086&DEV_0101&SUBSYS_84CA1043&REV_09\3&11583659&0&08
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_26733842&REV_A1\4&2ECE1234&0&0108
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_84CA1043&REV_C4\3&11583659&0&E4
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 8 - 1E1E
Device ID: PCI\VEN_8086&DEV_1E1E&SUBSYS_84CA1043&REV_C4\3&11583659&0&E7
Driver: n/a
Name: 2nd Generation Intel(R) Core(TM) Processor Family DRAM Controller - 0100
Device ID: PCI\VEN_8086&DEV_0100&SUBSYS_84CA1043&REV_09\3&11583659&0&00
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_26703842&REV_A1\4&1941C7EE&0&0109
Driver: n/a
Name: Intel(R) Z77 Express Chipset LPC Controller - 1E44
Device ID: PCI\VEN_8086&DEV_1E44&SUBSYS_84CA1043&REV_04\3&11583659&0&F8
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 4 - 1E16
Device ID: PCI\VEN_8086&DEV_1E16&SUBSYS_84CA1043&REV_C4\3&11583659&0&E3
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1B21&DEV_1080&SUBSYS_84891043&REV_03\4&2AACEACC&0&00E4
Driver: n/a
Name: AFS89CCM IDE Controller
Device ID: PCI\VEN_10B9&DEV_5228&SUBSYS_35D8B455&REV_01\4&5D18F2DF&0
Driver: n/a
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1E3A&SUBSYS_84CA1043&REV_04\3&11583659&0&B0
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 3 - 1E14
Device ID: PCI\VEN_8086&DEV_1E14&SUBSYS_84CA1043&REV_C4\3&11583659&0&E2
Driver: n/a
Name: ASMedia XHCI Controller
Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&D432303&0&00E2
Driver: n/a
Name: Intel(R) USB 3.0 eXtensible Host Controller
Device ID: PCI\VEN_8086&DEV_1E31&SUBSYS_84CA1043&REV_04\3&11583659&0&A0
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10
Device ID: PCI\VEN_8086&DEV_1E10&SUBSYS_84CA1043&REV_C4\3&11583659&0&E0
Driver: n/a
Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&3927C719&0&00E7
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
Device ID: PCI\VEN_8086&DEV_1E2D&SUBSYS_84CA1043&REV_04\3&11583659&0&D0
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_1E02&SUBSYS_84CA1043&REV_04\3&11583659&0&FA
Driver: n/a
Name: Asmedia 106x SATA Controller
Device ID: PCI\VEN_1B21&DEV_0612&SUBSYS_84B71043&REV_01\4&2543D5D&0&00E3
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
Device ID: PCI\VEN_8086&DEV_1E26&SUBSYS_84CA1043&REV_04\3&11583659&0&E8
Driver: n/a
Name: Intel(R) 82579V Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_1503&SUBSYS_849C1043&REV_04\3&11583659&0&C8
Driver: n/a
Name: NVIDIA GeForce GTX 670
Device ID: PCI\VEN_10DE&DEV_1189&SUBSYS_26733842&REV_A1\4&2ECE1234&0&0008
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller - 1E22
Device ID: PCI\VEN_8086&DEV_1E22&SUBSYS_84CA1043&REV_04\3&11583659&0&FB
Driver: n/a
Name: Xeon E3-1200/2nd Generation Intel(R) Core(TM) Processor Family PCI Express Controller - 0105
Device ID: PCI\VEN_8086&DEV_0105&SUBSYS_84CA1043&REV_09\3&11583659&0&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_1189&SUBSYS_26703842&REV_A1\4&1941C7EE&0&0009
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.18221
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
MS ATC Screen Decoder 1,0x00600800,1,1,scdec.dll,15.00.4545.1000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,16.04.3508.0205
Record Queue,0x00200000,1,1,WLXVAFilt.dll,16.04.3508.0205
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,16.04.3508.0205
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,16.04.3508.0205
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,16.04.3508.0205
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,16.04.3508.0205
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,16.04.3508.0205
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.16426
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17835
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
File Writer,0x00200000,1,0,WLXVAFilt.dll,16.04.3508.0205
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17835
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.18386
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.18386
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17835
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
FICV Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Desktop Microphone (3- Studio -,0x00200000,0,0,qcap.dll,6.06.7601.17514
Headset Microphone (Headset (Af,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Microsoft LifeCam Studio,0x00200000,1,1,LcProxy2.ax,3.60.0250.0000
Studio - Microsoft LifeCam.,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Headset (Afterglow Gamepad for Xbox 360),0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Optical Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Headset Earphone (Headset (Afterglow Gamepad for Xbox 360)),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
Headset Earphone (Headset (Afte,0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Wed May 07, 2014 5:52 pm
It shouldn't be caused by this, but I have noticed that you are using two computer screens. Could you unplug one of them and see if that changes anything?
Penx
Wed May 07, 2014 11:48 pm
Just attempted it and it is still not working.
Also if I am going to Live stream I need the second monitor. Without it I will not be able to read the chat.
TheToedOne
PC Specification: Lenovo Ideapad Y500, Win. 8.
Tue May 13, 2014 12:42 pm
So, I have been experiencing this same problem, I have also Submitted a support ticket, but I'm not sure that means anything. I will post again with the results of my Support ticket. hopefully they have a fix.... Hopefully.
"Poor Soul Ahead, Therefore, Praise the Sun!"
Penx
Fri May 23, 2014 5:29 am
So I just did a complete format and re install of Windows, and I am still getting this problem.
This is extremely annoying, I bought this program for the recording and streaming and I can't even use one of them.
From the ticket that I put in, I received, "remove your antivirus" even though I do not run one.
Can I at least get some kind of recognition that this is even being looked at anymore? Or was I, a paying customer, given up on?
Penx
Sat May 24, 2014 3:37 am
I think I may have fixed it, I am still in the process of testing right now but i have been streaming for an hour and not crashed.
These are the steps I took to get where I am at now...
1. Complete uninstall of Action!
2. Deleted all files with the name Mirillis or Action! (besides recorded videos).
3. Went to regedit and under...
>>> HKEY_CURRENT_USER >>> Software >>> Mirillis
I then deleted this regkey
4. Installed Action! to a different drive then my C:/
After those steps, I was able to stream for an hour at 720p.
I will update again once I do more testing and let you guys know if this is the fix
***EDIT***
I have confirmed that this works!!
Mods, if you can, can you please make this information public knowledge on the site, this was very frustrating for me and I know it can be for others.
Saber
Sun May 25, 2014 5:21 am
I am having the same issues as well, I've uninstalled the game, cleaned up the reg the best I could, installed an about an hour with 720 crash. Is this issue because of the free stream trial?
