Endomer
PC Specification: Intel, 64 bit, nvidea,windows 7
Solution - Suggestion.
Tue Apr 29, 2014 5:38 am
Hello Mirillis Support People,
I have a problem with Action only recording abuot 4.8gb at a time, but the software appearing to record for much longer. After searching through these forums I can also see that many people have similar issues which leads me to my point.
May I suggest that where Mirillis offers support or solutions (eg please send the log, contact support etc), Mirillis also then update the issue post with what the problem actually turned out to be and what fix was applied.
The forums are very light on actual solutions, and including them would reduce the duplicity and assist customers.
Thanks for reading. Cheers.
