littlecheese
PC Specification: i5 4670k, R9 280x, Windows 8.1
All sound is soft.
Fri May 02, 2014 4:53 pm
Whenever I play back a recording, the overall noise is very soft. I dont like how the sound settings makes it so that if you make your voice go up, it turns system sounds down. I want both to be up higher. Whenever i have both equal, i can barely be heard in the recording. But when i change it so i can hear myself better, then everything is softer and quieter. I always need to turn my volume up a lot when playing back recordings in order to hear everything like the way it was when i was playing it. Is there a way to make everything louder?
