Corcheedos
PC Specification: Windows7 GPU: AMD Radeon HD 7850
Recording 720p option???
Wed May 07, 2014 2:57 am
Hello I have bought Action recording software. It is great and working fine, but I am confused with one of the options in the main screen. The ''Video Size'' it basically the resolution you want the video to turn out , correct? Well I play in 1080p, but recording isn't so strong for me , for I perfer recording 720p quality like DxTory. Though that's really complicated, I bought mirillis action hoping all that complicated stuff would be gone. I was wrong I guess :/. Does this resolution thing even work? Or am I doing this wrong help
Re: Recording 720p option???
Wed May 07, 2014 5:22 pm
You can simply select the resolution from dropdown menu in Video Recording tab.
Corcheedos
Wed May 07, 2014 8:10 pm
I understand that, but I was hoping lowering the resolution would increase FPS performance, even if I put it to 480p the video looks 1080p .-.
Fri May 09, 2014 8:11 pm
Could you post a screenshot from your Video Recording tab and LIVE tab (second subtab)?
Corcheedos
Fri May 09, 2014 9:05 pm
http://prntscr.com/3hq7w5 <- screenshot of first tab
http://prntscr.com/3hq8ei <-- Screenshot of LIVE , I don't use it.
Return to “General Topics”
