Fish
PC Specification: i7 4770k, GTX 580ti, Windows 8.1 Pro
2 Problems - PTT Key + "Record to separate track"
Sat May 10, 2014 1:47 am
I have two problems. First (and least important), I can't use my normal push to talk key. Mirillis doesn't seem to recognize scroll lock as a viable hotkey. Are there any plans to add support at some point?
Second, when I use the "Record microphone into separate audio track" setting, I get NO microphone audio, at all. =/
DarkMain
Re: 2 Problems - PTT Key + "Record to separate track"
Sat May 10, 2014 4:52 am
Fish wrote:Second, when I use the "Record microphone into separate audio track" setting, I get NO microphone audio, at all. =/
Are you recording to AVI or MP4?
As far as I know MP4 doesn't support recording the microphone to a separate track.
vilias
PC Specification: Intel corei7, Nvidia 560Ti, Windows7 x64
Mon May 12, 2014 7:39 am
I have problem with PTT key also after the last update, I was recording mic only when I press a keybinding (CTRL) and it was fine but after the last update it is ignoring this option and record everything.
Any idea?
Thanks.
Legnakcalb
PC Specification: Windows 7 64-bit. i7-3770 3.40 ghz.
Tue May 13, 2014 12:22 am
You could make your push to talk key a key that you never use like... j for example and then bind your regular mic button on the mouse to the j key.
