Legnakcalb
PC Specification: Windows 7 64-bit. i7-3770 3.40 ghz.
Recording for 00:00:01
Mon May 12, 2014 3:39 am
Action! had been working since I bought it, but now something is wrong. The HUD appears in game like usual and it is blue, but when I press the record hotkey it does nothing. Then when I exit the game it shows a file has been recorded for 00:00:01 and that is it. I can play the file and watch it. I got it to work in a different game after a few presses of the hotkey, but I can't for the life of me get it to work in CS:GO. It just keeps recording the millisecond and does not turn red or anything. Any suggestions? The settings are all the same since I last successfully recorded with it and there is tons of space. I have also tried re-installing. What do I have to do to get it to work again?
Thank you
ACTION GAMER
PC Specification: Windows 8.1 PRO , GPU GTX 770M , i7-4700
Re: Recording for 00:00:01
Mon May 12, 2014 9:25 pm
i had same issue even support team cant solve my issue they refund me !
its only in game mode like that am i right ?
Legnakcalb
Tue May 13, 2014 12:21 am
Yes only in game mode. All other modes work and sometimes other games.
ACTION GAMER
Tue May 13, 2014 10:06 am
same mine
they cant solve the iusse
i just back to use Shadow Play
SysL
PC Specification: i7-960>EAH6950/2DI2S/2GD5>Win7-x64
Tue May 13, 2014 6:27 pm
same mine
Wolfeye78
PC Specification: i5-2400 @ 3.10GHz, RAM 12 GB, Windows 7
Thu May 15, 2014 10:21 am
Same problem here!
:cry:
Wed May 21, 2014 4:15 pm
Does it happen only with this particular game with all of you?
ACTION GAMER
Tue May 27, 2014 7:45 pm
its happenig for me all games
bad service they cant fix the issue i dont like saying that but its true
Wed May 28, 2014 11:21 am
ACTION GAMER wrote:its happenig for me all games
As it was mentioned many times. This is only a community forum, not a direct support help. If you would like to get direct help you should contact our support team via support@mirillis.com.
SysL
Tue Jun 03, 2014 5:21 pm
all games ..one way or another. i bought xsplit gamecaster.shame on you!
