Alberto22294
PC Specification: Intel i7-4820K CPU @ 3.70GHz
Recording Games at 1080p HD for Youtube
Wed May 14, 2014 5:11 pm
Allright, so I have looked this up for ever. I have followed a lot of peoples settings, while experimenting myself. I want to upload videos to youtube at 1080p HD. The game I play is called Firefall, and I play it on max graphics at 1920x1080. I want to be able to upload them at 1080p HD directly from Action! to Youtube if its possible, otherwise do I need another software? Thanks! It also seems to record everything on MP4 when I chose AVI anyways.
samuraikav
PC Specification: i7-3770, GTX 770, Windows 7 Home Premium
Re: Recording Games at 1080p HD for Youtube
Thu May 15, 2014 5:07 pm
The raw file may be AVI but when exporting it changes to MP4 from what I have found. As far as I know you can upload directly to YouTube. MP4 is generally a smaller file from what I know which is why it may export to MP4.
DIGG
Fri May 16, 2014 3:51 pm
You couldn't upload the raw AVI anyway, as the codec inside is proprietary of Mirillis; YouTube wouldn't be able to decode it. So either directly capture into MP4 (at lower resolution) or convert the AVI into MP4. :)
Wed May 21, 2014 4:13 pm
Mmake sure that LIVE streaming settings are not overwriting your recording settings. This situation occurs when "Enable Action! LIVE Streaming" option is checked.
