JoseMariaRex
PC Specification: PC Gaming
I can't open Mirillis Action!
Wed May 14, 2014 8:24 pm
Hi there,
I have just bought 2 licences for Action! and I can't open it. I downloaded the trial version and when I try to open it, it says "Action! has stopped working". I've never launched it, so I haven't got any recorded video/audio.
Here's a photo (in spanish):
Can anybody help me please? I really want to use Action! :(
Cheers,
Jose María
Mayorcete
PC Specification: i7, gtx760, w8
Re: I can't open Mirillis Action!
Thu May 15, 2014 4:15 pm
Same happens to me. Since today morning. Yesterday everything was fine
DIGG
Fri May 16, 2014 3:52 pm
*Try* to uninstall and reinstall the 1.19.1 version.
JoseMariaRex
Fri May 16, 2014 10:41 pm
DIGG wrote:*Try* to uninstall and reinstall the 1.19.1 version.
It doesn't work for me.
DIGG
Sat May 17, 2014 2:45 am
So no matter which version, it will never load? Ouch... I don't think the problem is with Action! if it's the case. :|
jax<>
PC Specification: Intel 3770K, Gigabyte 660GTX, Windows 7
Sat May 17, 2014 12:03 pm
Have you tried running Action in administrator mode, I have windows 7 and need to run it in this mode...
Mayorcete
Tue May 20, 2014 8:50 am
I tried as well with a clean reinstal and running Action in Admin mode. Nothing works, no way this can be our fault.
Mayorcete
Tue May 20, 2014 9:15 am
OK, something weird is happening to this program, but it seems I managed to fix it. I had it installed on W8. The tried comp. mode with W7. Didn't work, but then tried comp. mode with W8 and worked. Action is now running for me.
scoopsfl
PC Specification: Intel Core i7-4770 cpu @3.40 GHZ
Tue May 20, 2014 11:58 pm
I can no longer open...changed nothing...was trying to get it to work with FSX...no luck...then...it just stopped loading all together....uninstalled and re-installed....changed the compatibility to Vista... back to win 7...and back...installed as admin., ran as admin.
scoopsfl
Wed May 21, 2014 12:44 pm
I had a codec prob...updated.....running just fine now...hope this helps....just google codec update...very simple to do...if I can do it...it is simple....now if I can get aero to work....
