Claunator
Question about using license
Thu May 15, 2014 6:43 pm
Evening all!
I've been doing my research on safe ways to buy a license for Action. What came into my mind is a situation i MIGHT come across sometime in the future. After i buy a license, is it possible to "re-use" it if i change my PC? What i mean is i'm currently using Action on my gaming laptop but my future plans include custom-building a desktop PC for newer demanding games (e.g. Watch Dogs) and "moving" Action license to the desktop.
So, does it work if i uninstall Action from my current laptop and re-enter it on my future desktop IF i buy it before-hand?
DIGG
Re: Question about using license
Fri May 16, 2014 3:24 pm
I'm not representing Mirillis, but my *guess* would be that the license unlocks the program to use all the features. I reinstalled on a brand new system, entered my license and all, and the program does record. I haven't try running the program on 2 systems "at the same time", I wouldn't if they programmed it so only one might work at a time.
Wed May 21, 2014 4:14 pm
Yes, you can re-use your serial number to activate Action! on another PC but you have to uninstall it first from the previous one. If you purchase a single license you are allowed to activate Action! on one PC at the same time.
