DIGG
Action! won't record Diablo III
Fri May 16, 2014 3:15 pm
I recently bought a new computer system, reinstalled everything, and it's so much better now (i7 4770K oc'ed + GTX770 = winning!). Thought I'd go ahead and record something with Action!, but... it's not recording at all.
I want to record in fullscreen mode, so I select the 'Games and applications (DirectX/OpenGL)' in Action!, the HUD should be appearing within the game, but it isn't. And if I indeed start to record (by pressing the 'start recording' key), no actual capture is happening. I specify I can't record in fullscreen, cuz the second I swith to 'Windowed (Fullscreen)' within Diablo 3 and then select recording mode 'Active screen' in Action!, it does record... but I absolutely want to record Diablo 3 in fullscreen, as I augment the gamma a bit, and in windowed mode no gamma correction is applied.
I used to be able to record Diablo 3 games before, not 100% sure if I recorded them in fullscreen or windowed(fullscreen) mode, but I surely would want to record using YOUR software. I could start using the nVidia recording software what comes with the latest drivers, but I would much prefer use the software I paid for (hehe) with way more options!
Any thoughts on why it isn't working?
Update: I read some people having problems with the very latest update, so I reverted to version 1.19.1, and what do you know, I'm able to record perfectly *in fullscreen*. So *maybe* there's something wrong with the last patch... :?:
