DIGG
MP4 format not recording 60fps?
Sun May 18, 2014 11:24 pm
I tried to the first time to record in MP4 format (720p@60fps). While I was playing the HUD was showing 30fps, and now that I'm out of the game and checking the actual recording, it is indeed just 30fps.
Why is that? Why offer 60fps if it locks at 30fps? (fyi I'm playing Diablo 3, vsync'ed at 60fps, and I'm almost all the time at 60fps (some slowdowns here and there))
Re: MP4 format not recording 60fps?
Wed May 21, 2014 4:07 pm
MP4 is limited to 720p 60p with software encoding.
DIGG
Wed May 21, 2014 5:13 pm
Well, Action! shows "MP4" with "60 fps", but when I record it shows 30fps and the recorded file is indeed in 30fps. That's why I'm asking why we have the option to record at 60fps if stops at 30... :?:
This is Action! settings:
Yet the file is:
Format : MPEG-4
Format profile : Base Media / Version 1
Codec ID : mp41
File size : 10.3 MiB
Duration : 8s 367ms
Overall bit rate : 10.3 Mbps
Encoded date : UTC 2014-05-21 17:11:12
Tagged date : UTC 2014-05-21 17:11:12
Video
Format : AVC
Format profile : Baseline@L4.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Muxing mode : Container profile=Baseline@3.0
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 8s 367ms
Bit rate mode : Variable
Bit rate : 10.2 Mbps
Maximum bit rate : 25.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.369
Stream size : 10.2 MiB (99%)
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 8s 341ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 130 KiB (1%)
Language : English
MeiVincible
Mon May 26, 2014 5:37 pm
is LIVE streaming set to enabled? Make sure it's off. :)
DIGG
Mon May 26, 2014 6:28 pm
I do not stream at all. It is off.
MeiVincible
Mon May 26, 2014 11:24 pm
Just did a bit throughout testing here now, and for some reason, neither I can get more than 30fps with MP4 in any recording mode. (latest 1.19.2 used)
No issues with avi btw.
Is there anything specific needed to be set in order to reach higher frames? Otherwise I believe there is a bug.
I suggest go contact the support for further help.
Tue May 27, 2014 6:35 pm
As I stated earlier. Software encoding is limited to 720p 30p even if 60p is selected. To record in higher settings you need a hardware that supports Intel Quick Sync or AMD APP technology.
DIGG
Wed May 28, 2014 9:11 pm
Well... couldn't you GREY OUT the above 30fps options in the pulldown menu, if QuickSync isn't used? I understand and accept MP4 is limited to 30fps, but showing the 50 and 60fps options is stupid if it's not going to work.
Wouldn't you agree?
Thu May 29, 2014 11:43 am
DIGG wrote:Well... couldn't you GREY OUT the above 30fps options in the pulldown menu, if QuickSync isn't used? I understand and accept MP4 is limited to 30fps, but showing the 50 and 60fps options is stupid if it's not going to work.
Wouldn't you agree?
I agree, but I'm not the dev. I can suggest this for a next release but I guess there was a reason why this hasn't been grayed out.
