ReisHD
PC Specification: i5 3450 - GTX 660Ti SC 2GB EVGA - W7 64x
Action dont show ingame
Tue May 20, 2014 3:41 pm
I try to record FIFA 14 on PC but when i start the game after start Action Mirillis as an admin, the action dont show up on the game. I already tryed several times but action dont show up . .
DIGG
Re: Action dont show ingame
Tue May 20, 2014 5:22 pm
You selected the game capture mode?
samuraikav
PC Specification: i7-3770, GTX 770, Windows 7 Home Premium
Tue May 20, 2014 6:17 pm
What do you mean Action doesn't show up on the game? Are you looking for the FPS meter that will show if you're recording or not? Otherwise I don't know what would show up in the game itself.
If that's the case, you need to go to the HUD options and make sure that the option that says something like "Hide HUD in game capture mode" is unchecked. I can't give a picture as I'm not at home, sorry!
DIGG
Tue May 20, 2014 7:23 pm
This is how I do it:
That way I see the HUD ingame, and it's still showing WHILE it records, but the HUD itself isn't recorded. Simple. :)
Wed May 21, 2014 3:58 pm
Is that app running itself? Are you able to record other games?
