Could newer Catalyst drivers enable the 780G to show some of its power? I have to admit I haven't updated the HTPC's drivers for years
LOL I was just about to say that after reading the first section. I initally though you meant it doesn't work at all ^-^soulburner wrote: edit - okay, I forgot to tick the "Best quality" thingIt works, CPU usage is at 70-80%, even with Motion2 at max setting. Unfortunately, the interpolation often quits and many fast moving scenes are rendered at 24p. The same thing happens on my quad core, perhaps a little less frequently. Also, the amount of artifacts on moving objects or persons is very big, impossible not to notice on a large HDTV. Can't wait for Splash 1.0.1
Gonna have to refrain from buying Pro at the moment until it is fixed - it is very promising, though, so keep up the good work! Now that the licensing stuff are out of the road, perhaps the developers can focus on fixing things
