videogramez
PC Specification: i5 2500K, NVIDIA GeForce 560Ti, Win7 x64
Exporting (Encoding) 2560x1080 (ultrawide 1080p) video
Mon Jun 02, 2014 8:27 am
Is there any way to set it to encode at that ultrawide 1080p resolution?
No matter what option I pick it seems to encode at only 1920x810 ....
Claunator
Re: Encoding 2560x1080 (ultrawide 1080p)
Mon Jun 02, 2014 3:04 pm
It should record whatever resolution u're playing on with the "Original" option. If u're using multiple monitors, then it might think u're using all that resolution on one monitor which could cause the error. I'm just thinking that, i'm not an expert on this.
videogramez
Tue Jun 03, 2014 8:18 am
Right, it can record 2560x1080 just fine when set to Original, but every option for encoding/exporting the video resizes it to 1920x810 at most.
Re: Exporting (Encoding) 2560x1080 (ultrawide 1080p) video
Wed Jun 04, 2014 5:06 pm
MP4 files currently cannot keep the Original resolution. It always scaled to 1920x1080p.
