Romannet
PC Specification: CPU: X4 3,4 Ghz, EAH 6870, MSI 870 A-G54
Preview glitch in VEGAS
Tue Jun 03, 2014 1:12 am
Hello
I was desperate and please help
when I put the video to vegas, recorded from Mirillis Action, incurred by different visual errors
Emergence of this visual error is purely random.
Please any advice on what I should change in Vegas, so don't create these visual errors
Thanks for reply
Re: Preview glitch in VEGAS
Wed Jun 04, 2014 5:08 pm
Does this visual glitch shows only in preview or rendered file also got these bugs?
Romannet
Wed Jun 04, 2014 7:57 pm
This bug appears in the preview time, and also the final render, screenshots were made from the final video. Mirillis Action makes clear video, Vegas makes clear video but together (Action + Vegas) create these bugs,
Thanks for reply
Thu Jun 05, 2014 6:51 pm
Romannet wrote:This bug appears in the preview time, and also the final render, screenshots were made from the final video. Mirillis Action makes clear video, Vegas makes clear video but together (Action + Vegas) create these bugs,
Thanks for reply
Please report this to our support team. It would be great if you could attach your original video.
alexondro
PC Specification: intel core i7 gtx 550ti windows 7 64 bit
Fri Jun 06, 2014 7:37 am
Romannet wrote:Hello
Thanks for reply
Please let me know, if you will find any solutions, thank you!
MeiVincible
Thu Jun 12, 2014 12:46 am
I've actually experience this too in vegas and seem to occur mostly when I have two video tracks added with recording stuff. And yes it appears too in the final rendered video. I use Vegas Pro 11 build 701.
Thu Jun 12, 2014 10:40 am
I was able to get the same result in my Vegas, but this did not occur with Adobe After Effects. Have you checked Sony forums for similar issues? Maybe the app itself cannot handle video effects.
Cauptain
Contact: ICQ
Fri Jun 13, 2014 11:26 am
Thanks for reply
Whats Vegas version? OS used? Some Codec Pack?
Upload a 10 seconds file. Its very necessary to help u.
Claudio
Romannet
Fri Jun 13, 2014 2:23 pm
Thanks for reply
Claudio
I have, Vegas Pro 13 (Build 290) 64-bit, OS: Windows 8, this same glitch on 8.1, Codec pack: I'm not installing anything specific, just default in Windows ...
In the following links you will find 2x videos recorded from Mirillis Action, also send a screenshot of my Vegas where to see a clear visual problems.
2x VIDEOS:
http://www.adrive.com/public/uxSctZ/Vid ... -03-02.avi
http://www.adrive.com/public/2c8VBb/bf4 ... -36-59.avi
Thanks for any reply :)
Cauptain
Contact: ICQ
Fri Jun 13, 2014 4:16 pm
Download and test.
Using Windows 7 X64 + Vegas 12 = Same bug. Its a compatible error on Vegas, using 2 FICV files.
I convert the effect video to RGB (UT VIDEO lossless codec). Its OK now.
Its a Sovy Vegas error, send the issue to Sony support.
Claudio
