PrinzMegahertz
PC Specification: Intel Xeon v3, MSI GTX 770 Win 7,
Youtube: Unsupported file format?
Fri Jun 13, 2014 3:51 pm
Hi guys,
I recorded a video with Action! and youtube tells me that the file format is not supported. I am using the AVI format and do not record a separate audio track for the microfone.
I can also watch the video on my pc using windows media player.
Any ideas why youtube does not like the video? I wanted to use Action! so that I do not have to render the videos separatly.
Claunator
Re: Youtube: Unsupported file format?
Fri Jun 13, 2014 4:23 pm
AVI is encoded by FICV. It's Mirillis' own codec. If u want to upload straight to Youtube without editing, u have to use Intel Quick Sync/AMD APP.
LtMatt
PC Specification: 2700k, 2x290 Crossfire, Win 8.1 64 bit.
Sat Jun 14, 2014 8:05 am
Claunator wrote:AVI is encoded by FICV. It's Mirillis' own codec. If u want to upload straight to Youtube without editing, u have to use Intel Quick Sync/AMD APP.
Which is the best quality? Youtube seems to lower the video quality quite badly no matter what i do.
Claunator
Mon Jun 16, 2014 10:11 am
If u're looking to leave editing out, ur best bet is to use the following settings:
Format: Intel Quick Sync / AMD APP
Recording FPS: 30 or 60, i recommend 30 since Youtube only supports up to 30 FPS
Quality: High
MP4 bitrate: 100%
Cauptain
Contact: ICQ
Mon Jun 16, 2014 1:24 pm
Claunator wrote:If u're looking to leave editing out, ur best bet is to use the following settings:
Quality: High
MP4 bitrate: 100%
Recording FPS: maximum FPS here.
Why? Simple. Youtube use VFR, its make your video more fluid then 30fps set in Action.
Claudio
Users browsing this forum: No registered users and 51 guests
