mel2401
PC Specification: Intel I7 3.6ghz, MSI 690 GTX, Win 8 64
Audio Boost
Mon Jun 28, 2010 9:21 am
There seems to be a problem with audio boost not persisting when Splash is closed and then reopened. Even If I create a custom preset it still is unticked whenever I run the player.
Helios
Re: Audio Boost
Mon Jun 28, 2010 1:45 pm
Hi mel2401,
We decided to reset Audio Boost every time application starts, because it is needed only in quiet encoded files.
It can be harmfull, when you open a file by double click and it plays at 500% volume.
regards,
mel2401
Re: Audio Boost
Tue Jul 06, 2010 8:59 am
Any possibility of including a command line switch to override this auto setting so that we can make a concious decision to always have it on?
mel2401
Re: Audio Boost
Mon Sep 06, 2010 7:01 pm
I see that the Mirillis team are even directing other people to this post, however there has been no communication from the team regarding this or my other request for a resume/bookmark feature. We have had two releases since then though if i'm not mistaken. I am a programmer with over 25 years experience and would be glad to implement this change for you.
Joco1114
Re: Audio Boost
Tue Sep 07, 2010 4:46 am
I can help too, although I have only 20 yrs long experience. :D
Home Theater:
Synology NAS 1010+ | 9TB HDD
Re: Audio Boost
Mon Sep 20, 2010 4:43 pm
Audio boost is remembered now in presets. Check latest version.
