Ronar1
PC Specification: i7, Nvidia, Win7, 8GB RAM
Audio Skipping/Stuttering League of Legends
Fri Jun 20, 2014 7:19 pm
Hi so I'm a new user here currently running the free trial and I'm very impressed by the no lag and small file size recording aspects of Action! In fact I'm just about set to buy the license, but there is one problem making me hesitant and it seems to only apply to league of legends.
During recording the audio seems to skip or stutter. For example when the announcer would normally announce a "DOUBLE KILL" it will instead be "DO-DOU-DOUBLE KILL" and it happens frequently and consistently (but not every time).
From what I've seen this is some effect that Action! has on the league client and on nothing else, the microphone audio never does this and you can hear the stuttering in game. So its causing the league client to stutter and then records the stuttering.
I tried recording the video and audio separately and in one file together. Both times there is the audio lag.
Something I noticed is that saving the file as an MP4 the audio lag is gone. But It won't be available in 1080p if I save it in an MP4 file.
This is probably one of the best no lag softwares I've seen thus far and it'd really be a shame if I can't get it only because of the audio lag, please help!
i7, win7, 8GB Ram, Nvidia, Vaio F series, probably isn't due to specs issues.
Re: Audio Skipping/Stuttering League of Legends
Wed Jun 25, 2014 4:20 pm
League of Legends is using lots of system resources including hard drive. When you are recording into the same hard drive where your game is installed there may be a performance issue like dropping frame rates and problems with reading game data. Please try lowering your resolution or change your output folder to another hard drive.
