dingo
PC Specification: i7 4770k,cf r9 290,etc etc
Action video lag.
Sat Jun 21, 2014 8:34 am
So when i record a gameplay, i try to play it in vlc,Sony Vegas ,KMplayer etc, & every video lags, it's impossible to play it in Sony Vegas because it just skips frame.
Like this: Image
Action settings.
http://gyazo.com/09dc189788aa0f3512194124c2d61b2c
http://gyazo.com/7e14d8ee2483b89e6793a5a6f4bf8c04
http://gyazo.com/b6648221b090e77f057ff2e256f5e918
my system is i7 4770k oc 4.3/ CF r9 290/2560x1440 monitor/samsung evo 250gb/videos recorded to wd 1tb blue.
windows 8.1.
I've tried installing ffdshow codec/some other codec used ccleaner & nothing works.
unless i'm doing something wrong.
Cauptain
Contact: ICQ
Re: Action video lag.
Sun Jun 22, 2014 12:17 pm
Disable Multicore Record and try again.
If problem continue, load MSI Afterburner and try using video output MJPEG 100%.
If LAG too, probably, resolution issue.
Claudio
dingo
Sun Jun 22, 2014 5:09 pm
Tried all that i also have a 1920x1080 monitor tried that & nothing,now for some reason even dxtory is also not working properly after i installed Action. i'll just format & install windows 7.
i'm guessing it has to do with Action codec or something or windows 8.1.
Cauptain
Contact: ICQ
Sun Jun 22, 2014 7:59 pm
I have a R290 too and have Action!, Dxtory, Bandicam, Playclaw and Fraps. Both works perfectly on my Windows 7.
Windows 8/8.1 have some compatibility issues with various softwares.
Claudio
dingo
Mon Jun 23, 2014 6:05 am
changed to windows 7 action is working good in sony vegas.
Now Dxtory doesn't want to work right with lagarith lossless codec,but that's ok.
Now my other question is How come Action from like 90-120avg fps in bf4 max settings with action its dropping to 45-60fps avg. vsync off on bf4.
Cauptain
Contact: ICQ
Mon Jun 23, 2014 2:12 pm
dingo wrote:changed to windows 7 action is working good in sony vegas.
For Dxtory use UT VIDEO RGB only. Its "beat" Lagarith in stability and decoder speed. Try and reply.
Link: http://www.videohelp.com/download/utvid ... .0-win.exe
BF4 have various problems with any capture record. Its a luck case.
Claudio
dingo
Mon Jun 23, 2014 9:25 pm
tried it it works perfectly in sony vegas.
but 2 things i still lose like 25-35 fps.
& like a min video like 10+gb yes i'm recording @ 60fps @ 2560x1440
Action would be perfect if i won't lose so much fps
action like a min video is 3gb or less can't recall .
Dxtory settings with that codec.
http://gyazo.com/8a0a23d7dcb2f488322e6ee9004d5f23
http://gyazo.com/54ca0258fe3c79c15cece1c70ea9f9d2
i've tried it with check & uncheck on.
enabled multi gpu fix code
& Force cpu processing.
i'm willing to lose up to 10 fps but not 15+ fps
i'll see what i can do.
Cauptain
Contact: ICQ
Tue Jun 24, 2014 12:22 am
Make a another test using UT VIDEO YUV420 BT.709
Mirillis Team are working in this issue in BF4.
Look your MP
Claudio
Users browsing this forum: No registered users and 75 guests
