SenseiTech
PC Specification: Windows 7 x64bit
Action! has stopped working!
Tue Jun 24, 2014 5:23 pm
Hello fellow reader,
So I wanted to try the Action! recorder and so I installed the trail version. I installed it with no problems. I went to open it but an error occured.
"Action! has stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is
available"
I dont know what happened so I went to the interwebs to check for a solution, didnt find any that worked for me. So is there any solution? I have Windows 7 x64bit if that helps.
-SenseiTech
Re: Action! has stopped working!
Wed Jun 25, 2014 4:24 pm
Please post a DxDiag report of your PC.
lloydesands19
Thu Jun 26, 2014 10:31 pm
radi wrote:Please post a DxDiag report of your PC.
how do you post dxDiag?
SenseiTech
Sat Jun 28, 2014 6:09 pm
http://pastebin.com/4LYdxX8E
Sorry if this isnt what you wanted...
Mon Jun 30, 2014 4:33 pm
This is exactly what I needed. Please update your AMD drivers to latest available.
SenseiTech
Tue Jul 01, 2014 1:19 am
Can you explain how you should update a driver, because I went into my System Properties, then Device Manager, then to the display adapter and I updated it. I tried out Action! and still the same error. Did I do something wrong?
-SenseiTechUS
Tue Jul 01, 2014 10:26 am
The best way is to use AMD auto detect tool. You can find it here: www.support.amd.com/en-us/download/auto-detect-tool
SenseiTech
Tue Jul 01, 2014 8:05 pm
Okay, so I got the correct driver to be installed, I installed it. I tried to open Action! once again, and the same thing happened. When I installed the driver, a seperate program came with it, AMD Gaming Evolved and said my Driver hasnt updated. I dont know why it hasnt updated since I installed the driver..
-SenseiTechUS
zandermundell
PC Specification: Windows 7 ultimate 64-bit
Wed Jul 02, 2014 3:28 am
i have the exact same problem however mine only began when i tried updating my Graphics card drivers and AMD auto detect install the wrong graphics card drivers and when i was forced to reset the drivers to the original ones since then i have not been able to launch action! it gives me the same error
Wed Jul 02, 2014 3:44 pm
I guess that the issue is related to faulty (?) drivers or something similar.
