Chazypax
PC Specification: i5 3570K@4.3GHz, GTX 660, Win 7 64bit
Action! AVI > MP4 Lag - Voice audio suttering and scrabbled.
Thu Jun 26, 2014 9:34 pm
Hi All,
I have purchased Action and I find its a great bit of software.
I have a few problems though which are quite annoying.
I play Microsoft Flight Simulator X and Action obviously records it to an AVI file. I record at 1080 HD. Just to note, the FPS counter from Action when in game, and it says DX9 meaning that its recording it in direct x 9...
When I watch the video back the video is smooth with no visual suttering but for some reason my voice over is scrabbling and stuttering?
I then export the video from an AVI to an MP4 using Actions exporter. I export to a 1080p high profile and the quality for export is also set to high.
When I watch the MP4 back I notice a major lag on the video? Here is the link to the video to demonstrate all of this:
https://www.youtube.com/watch?v=ym2tcjuTy5E
I also record Arma 3 with the exact same settings and export options and its absolutely fine however Arma 3 is DX11. Could this have something to do with it the fact FSX is DX9?
Any help would be much appreciated.
Regards.
Re: Action! AVI > MP4 Lag - Voice audio suttering and scrabb
Fri Jun 27, 2014 3:58 pm
The audio glitches sounds like performance issue. Do you record into the same hard drive where your game is installed? Could you please create a test video and record to 360p and see if the same issue occurs?
Chazypax
Fri Jun 27, 2014 7:29 pm
Yes I have my game installed to my hardrive (c drive) and I also have my Action! recording to the c drive so yes, I am recording to the drive in which my game is on.
I just tried a test video with exactly the same settings and recorded it in 360p instead (to my c drive). The audio from my mic seems absolutely fine with no problems at all.
Should I try to record 1080p videos to my external hardrive?
Chazypax
Fri Jun 27, 2014 7:56 pm
I have tried recording my videos in 1080 high profile to my external hardrive and the sound problem is still there slightly but not as much. However I export my video to MP4 on the same external drive and I get the same lag again.
Mon Jun 30, 2014 4:38 pm
Unfortunately I'm not able to help. Please contact our support team via support@mirillis.com.
Users browsing this forum: No registered users and 79 guests
