gamer658
PC Specification: Windows 8
Transfering Action Questions
Mon Jun 30, 2014 6:09 am
Hello, recently I had just purchased a new PC and had registered Action! for a free trial on it. However, I also have the actual version of Action! on my laptop which I hope to transfer to my PC in order to activate it. My question is that if I have recordings on both programs, when I transfer it will it save both of my Trial recordings and actual recordings, or will it only save one but not the other. Basically, if I transfer it to my new PC, will ALL of my recordings be saved on both programs.
Thanks for taking the time to view my questions, I look forward in getting an answer.
Re: Transfering Action Questions
Mon Jun 30, 2014 4:26 pm
Your videos are located in output folder. If you will copy the output folder then you will have your recordings.
