Caseybear
PC Specification: Windows 7, Intel i7, Radeon 7800
Wont screenshot with hotkey
Mon Jun 30, 2014 12:04 pm
Every time I try to do screenshots with the hot key 'F12' It doesn't work. I've also tried changing the hot key and it still doesn't work. If i press the big button on the screenshot page it'll work but just not the hot key. How do I fix this.
Re: Wont screenshot with hotkey
Mon Jun 30, 2014 4:26 pm
Could you post a screenshot of your hotkey section?
Caseybear
Mon Jun 30, 2014 6:45 pm
I'm aware its grayed out beside it but the record video button will still work and that's grayed out too.
Wed Jul 02, 2014 3:47 pm
Grayed buttons means that they cannot be disabled. I guess that there is some other applications that is not allowing Action! to use F12 to capture screenshot.
