PurpleCoin7777
PC Specification: Windows 8.1
Cuts most of the video out.
Tue Jul 08, 2014 3:37 pm
I bought Action about a month ago and started to record Minecraft videos with it. This used to happen half the time, but now all the time.
When I record a video, it says everything is recording and when I stop and look at the video file, most of the video is cut out.
I use Windows 8.1 and my settings are all default except I made the frame thing at the top right disappear.
Is there any way to fix this?
founder3
PC Specification: AMD Black Ed. 7750, Radeon HD 7870, Win7
Re: Cuts most of the video out.
Thu Jul 10, 2014 11:32 am
Are you recording in AMD APP?
If so, have you tried recording in either regular MP4 or AVI format?
I had this same issue and it was due to an incompatible CPU/GPU combination.
Hope this gives you something useful in the long run.
PurpleCoin7777
Thu Jul 10, 2014 10:00 pm
Bump.
PurpleCoin7777
Sat Jul 12, 2014 5:30 pm
I record in MP4.
PurpleCoin7777
Tue Jul 15, 2014 4:03 pm
I really need this fixed :(
Tue Jul 15, 2014 4:05 pm
What's your CPU usage during recording when this issue occurs?
PurpleCoin7777
Tue Jul 15, 2014 4:18 pm
It's different every time, sometimes 20%, sometimes 100%
Wed Jul 16, 2014 3:27 pm
PurpleCoin7777 wrote:It's different every time, sometimes 20%, sometimes 100%
The issue probably occurs when the CPU is overloaded (near 100%). Our developers currently are looking into this. When the CPU is overloaded glitches may occur but the video shouldn't end.
