bayc
PC Specification: Windows 7
Action! Won't Open
Tue Jul 15, 2014 7:14 pm
I double click on action! shortcut on my desktop, and it won't open. The little banner thing (idk how to describe it) pops up, but then the program never does.
Re: Action! Won't Open
Wed Jul 16, 2014 3:25 pm
Do you use Wi-Fi or direct internet connection?
bayc
Wed Jul 16, 2014 10:47 pm
I use direct. It opened now though, so I guess I just needed to restart.
Thu Jul 17, 2014 1:46 pm
There was a similar issue in the past where Action! was blocked on user router and it resulted in getting stuck on the loading screen. Try unplugging physically your internet connection and see if you can get past through the loading screen.
