Patch for MP4 AMD 60 FPS?!radi wrote:Next one will be a big one
AMD APP is already available with 60 fps.MrTra1tor wrote:Patch for MP4 AMD 60 FPS?!radi wrote:Next one will be a big one
Yes, but it's extremely buggy for most games. The playback starts to lag a lot after a few seconds and then the audio goes away and it turns into a slideshow for the next minute, then it stopsradi wrote:AMD APP is already available with 60 fps.MrTra1tor wrote:Patch for MP4 AMD 60 FPS?!radi wrote:Next one will be a big one
How do I check that without cutting the recording?radi wrote:What's your CPU usage during recording when these glitches occurs?
Open your task manager and create a short recording like always. Then stop it and look into the CPU Usage history.MrTra1tor wrote:How do I check that without cutting the recording?radi wrote:What's your CPU usage during recording when these glitches occurs?
Oh, it saves the history. Thanks, I will do that once I get home from Stockholm on Fridayradi wrote:Open your task manager and create a short recording like always. Then stop it and look into the CPU Usage history.MrTra1tor wrote:How do I check that without cutting the recording?radi wrote:What's your CPU usage during recording when these glitches occurs?
