DatGuyWhoGamez
PC Specification: Windows 8 Intel core i7 4700MQ
Action crashes as soon as it starts
Fri Jul 18, 2014 12:14 pm
I can provide any information you might need but basically when I start action I get the error"Action! has stopped working" (the Fps counter shows up for a few seconds too)
I am really confused to why this is happening I have no action processes running I tried reinstalling. Running as admin. Etc. Any ideas?
Re: Action crashes as soon as it starts
Fri Jul 18, 2014 12:21 pm
Could you post your DxDiag report?
DatGuyWhoGamez
Fri Jul 18, 2014 1:10 pm
I cant seem to fit the report into the post :/ Max characters is 60k Aparantely its 84612
Fri Jul 18, 2014 2:06 pm
Please try removing or moving to another location all your files from your output folder. If that does not help contact our support team directly via support@mirillis.com.
DatGuyWhoGamez
Fri Jul 18, 2014 2:37 pm
radi wrote:Please try removing or moving to another location all your files from your output folder. If that does not help contact our support team directly via support@mirillis.com.
Worked perfectly! Thanks for the help :D
