DPG_DJ
PC Specification: Intel i5-2500k, Geforce 660 GTX
I'm trying to figure out some solutions.
Tue Jul 22, 2014 2:32 am
Hi, I was using the trail version of Action!, and this problem occurred. After I was recording, I was trying to play the file with Windows Media Player(WMP), It will not play the file! Problem 2: After checking the box "Record mincrophone in seprate audio track". I try importing the video with the two audio paths into adobe premiere(Pr). Unfortunately Pr can't import video with two audio paths(Or can't even import it at all!). So, you may ask yourself, why is it in this forum? I figured that I was not the only person that had this problem and most likely had the problem resolved, asking for help here than in adobe forums. So I am looking for the answer for how to change the setting to make it work with WMP. Plus, I'm looking for an answer to resolve the second problem with Pr. As soon as I have this problem resolved, I will buy it! So to add on I don't really care if I have to extract the audio before importing it. It's just I don't know how to do that in the best way possible!
Re: I'm trying to figure out some solutions.
Tue Jul 22, 2014 6:59 am
Do you experience any error message while trying to playback your video file in WMP? Can you playback this video using Action! player?
Adobe Premiere does not support video files with more than one audio track. However you can export the second audio track (microphone audio) using simple and free software like VirtualDub.
DPG_DJ
Tue Jul 22, 2014 2:45 pm
Thanks for replying so quickly! In WMP it plays just the game sound, no video. It does play it in Action! Player, but the file will not open in VirtualDub.
Wed Jul 23, 2014 3:30 pm
I guess there is some decoder missing. Try re-installing your Action! so the video decoder will overwrite the current one.
DPG_DJ
Wed Jul 23, 2014 6:31 pm
Um, still the same result. Plus, it says on the VD http://imgur.com/pwUlnPU . Question: Do I have to check the box muti-channel ?
DPG_DJ
Thu Jul 24, 2014 2:09 am
This the message I get attempting to import the avi file:Image
Thu Jul 24, 2014 12:59 pm
I guess they does not support our FICV video codec which is weird because many of our users work on Adobe software to edit their videos. Do you have any other codecs installed on your PC?
DPG_DJ
Thu Jul 24, 2014 4:44 pm
Image Here is the list from WMP.
DPG_DJ
Thu Jul 24, 2014 4:49 pm
Looks like I'm missing the codec, do you think its because the trail version will not download it for me?
If so, can I get a safe download link?
Fri Jul 25, 2014 6:54 am
I don't see our FICV there. FICV is installed along with our app. Try downloading and installing one of our trial Splash players. They also should contain the FICV codec.
