n0thing15
PC Specification: i5-3330 Gtx650ti 1 gb Win 8.1 Pro x 64
Steam OVERLAY Not Recording.
Thu Jul 24, 2014 11:43 am
Hi mirillis team!
I have a problem....whenever i try to record Team Fortress 2 it doesn't record the steam overlay when i press SHIFT+TAB. However when i try to record Garry's Mode it works!
As far as i know both of them run on the Source Engine which is using Directx 9.
Currently using the latest version of Mirillis Action.
Running Windows 8.1 x64 bits
Things i've tried.
1.Exlucde.txt -> Doesn't work.
2.Things like Opening Action before and after openning steam or the game -> Still doesn't work.
//A friend of mine that is using Windows 7 doesn't have any problems.....Can you help me guys?
#EDit: I tried other games and they work....help me i am desperate.
#Edit2: Tried Terraria, Unturned and some other games and they don't work... exactly like TF2.
Regards!
n0thing15
Re: Steam OVERLAY Not Recording.
Sun Jul 27, 2014 12:45 pm
Any help?
PLEASe?
Mon Jul 28, 2014 4:38 pm
Is the Steam Overlay above or under the HUD?
n0thing15
Mon Jul 28, 2014 8:12 pm
radi wrote:Is the Steam Overlay above or under the HUD?
Thank you for the response.
The Steam Overlay is above the HUD.
If the steam overlay was under the HUD it would work.....
Tue Jul 29, 2014 8:37 am
Exactly what I meant. Both Steam overlay and Action! plug into your game process separately. Depends on which one will plug into your game first it will be below the second app that plug into your game. The weird thing is that you have tried running your game first and then run Action! which didn't work.
n0thing15
Sat Aug 09, 2014 1:56 pm
Is there anything i can do?
My friend has Win 8.1 Enterprise x64 and i have Win 8.1 Pro x64.
We have the same problem.
Mon Aug 11, 2014 5:49 pm
n0thing15 wrote:Is there anything i can do?
Have you tried changing the priority for Steam to high and lower it for Action?
