BrightSpectrum
PC Specification: Windows 7
Problem with moving files to Vegas Pro
Fri Jul 25, 2014 12:24 am
So I'm having a bit of an issue when trying to move the recorded files from action to Vegas. I know how to do it but when I try opening it up in Vegas Pro, it says there's a problem with the codec. I'm not a computer genius, so I have no idea what that means. Can someone help please? Thanks.
Re: Problem with moving files to Vegas Pro
Fri Jul 25, 2014 6:49 am
Are you trying to import AVI or MP4 file?
BrightSpectrum
Fri Jul 25, 2014 5:44 pm
AVI
Mon Jul 28, 2014 4:44 pm
hej
Sat Aug 02, 2014 7:45 pm
If you're recording in uncopmpressed AVI you then need to encode those raw files within Action!.
This is what I did until they got AMD APP Mp4 support, now it is encoded on the fly :)
