Dmitriandr
PC Specification: Intel core i5 3570K
Don't working record webcam!
Sat Jul 26, 2014 5:23 pm
Hi everyone! In short, I had a serious problem! After two video overlay recording from a webcam, I have lost the image from the webcam. That is, I can not now record video games and desktop overlay record from webcam (((already Tried everything - from reinstalling the program to install other versions. Nothing helps! By the way, when you open a window with a sample overlay web camera, then webcam LED lights. a picture is still not visible. And even virtual web-ka from Manycam not displayed. So it's not in my webcam Logitech C250. Especially in Skype, in mail-agent in browsers and other applications, my webcam works fine :|
Dmitriandr
Re: Don't working record webcam!
Mon Jul 28, 2014 3:04 am
I myself have found the problem. Now all right :P !
MrCocoMacoStick
PC Specification: Windows 7
Wed Sep 24, 2014 12:30 pm
Hi there what was it you did to fix this problem
Mon Sep 29, 2014 5:22 pm
Webcam may not be working in two cases:
- Check if you have Perfect Video Match mode enabled. If yes, please disable it.
- Check if you have selected Record Mouse Cursor, it's required to show the webcam properly.
