axeltow
PC Specification: i5 3750K, AMD 7950, Win 7
Action won't record audio with Mouse 3 (Middle Mouse)
Tue Jul 29, 2014 10:26 pm
Hi guys here are my specs, although I guess this is an application thingie
OS: Win 7
Video: AMD 7950
Memory: 16GB
Mon Res: 1920x10180
So, I use TeamSpeak when I play and my push-to-talk is Mouse 3 or Middle Mouse. The problem is that I can't set that specific key in the Action settings to record my audio. Is this possible or some keys are restricted for being used in the application?
Thank you kindly in advance and cheers for a really great product!!
Re: Action won't record audio with Mouse 3 (Middle Mouse)
Fri Aug 01, 2014 3:51 pm
As far as I know there is no possibility to set M3 as a hotkey. Only 4 and 5 was available.
axeltow
Sat Aug 02, 2014 11:10 pm
That is quite unfortunate. Do you know if there is a particular reason for that?
Thanks for the answer though. Keep up the good work!
Tue Aug 05, 2014 3:23 pm
axeltow wrote:That is quite unfortunate. Do you know if there is a particular reason for that?
I guess it's due to some technical reasons. I will ask the devs.
axeltow
Thu Feb 05, 2015 9:41 am
Hi again,
I figured I'd ask the question since I've been meaning to test Action again. Do you know if with 1.2.1 you can use M3 to record your voice?
Users browsing this forum: No registered users and 62 guests
