DaRosc
PC Specification: windows 8
remote server connection
Sat Aug 02, 2014 4:28 pm
Hey, I have been having a problem with uploading videos for the past week. Each time I try to upload a file to YouTube, the exporting process completes without any problems. However, the moment it enters the uploading process, two notifications appear. One reads " Upload failed" and the other reads " Connection with remote server failed". This has happened without fail every time, no matter which video I try to upload. File size does not seem to have any affect. As I do frequently upload gaming videos, this is a serious problem that is affecting my ability to run my channel. Could this issue please be fixed as soon as possible? Thank you.
Re: remote server connection
Tue Aug 05, 2014 3:25 pm
Do you use any anti-virus software?
DaRosc
Wed Aug 06, 2014 4:46 pm
Yes, I do. However, the problem has rectified itself since I posted this complaint. I'm not sure what changed, but the software seems to be functioning correctly. Thanks for trying to help.
TOPGUNxICEMAN
PC Specification: windows 8 amd 7770
Wed Aug 06, 2014 7:25 pm
this is happening to me as well. i had norton but my subscription has been over for almost a year. my web browser is Firefox and i use adblock can you please help me ASAP thanks
